02-09-2022
10:11
11:58
02-09-2022
10:11
11:58
My versa 2 is failing to sync, tried turning Bluetooth off and on but still nothing. Been like that since Saturday.
02-11-2022 11:59 - edited 10-30-2023 05:07
Hi there, @Diane5261. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand how you must be feeling.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 3 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 3.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 3.
Hope that helps.
02-09-2022 12:38
02-09-2022 12:38
Mines the same 🙁
Best Answer02-11-2022 11:59 - edited 10-30-2023 05:07
Hope that helps.
