07-01-2022
13:25
16:39
07-01-2022
13:25
16:39
My Versa 2 has stopped working altogether. Even after being on charge it still doesn’t turn on . I’ve tried all the usual troubleshooting but nothing helps . The green light on the back doesn’t even light up anymore either . Can anyone help ?
Hi there, @Shirl74. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
In addition to the steps you tried, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope that helps.
Hope that helps.
@Shirl74 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
