04-26-2023
05:04
05:36
04-26-2023
05:04
05:36
I haven't used my fitbit in 6 months (lost it but found it in a drawer) I've tried resetting it, doesn't work, the screen is completely blank, it buzzes when I press the button for about fifteen to twenty seconds, but nothing else, I have tried charging it, and cleaned it thoroughly, it also won't sync to the app due to it not turning on
04-26-2023 05:39
04-26-2023 05:39
Hi there, @Leila333. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?.
If the restart doesn't work, I'd suggest trying the below steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove the Versa 2 from the phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer04-26-2023 05:40
04-26-2023 05:40
Hi @Leila333 That is sad for you, but it may be a a battery issue - lithium ion batteries don't like being flat for long periods. But I may be something else. If the long press of the button doesn't help there js probably nothing you can do. Sorry
Helen | Western Australia
