05-30-2024 05:44
05-30-2024 05:44
My versa 2 will not wake when I press the side button. If I hold it down, it pops up the logo like it's restarting and then says 'data not cleared. Sync and try again.' App says it last synced 10 hours ago and will not sync again. Any suggestions?
05-30-2024 05:56
05-30-2024 05:56
Hi, @authorsgirl98! Try holding the button down for ten seconds to perform the restart. If that doesn't work, there are some nuclear options you can take, like a factory reset.
MakMak | Community Council
Best Answer05-30-2024 07:13
05-30-2024 07:13
It comes up with the same error when I do that.
Best Answer05-30-2024 07:22
05-30-2024 07:22
You can try doing the tricks in this article for forcing the Fitbit to sync, that's probably a good start.
Next you can try contacting support.
If you want to try a factory reset, you can do it this way:
Just note that this means the device will no longer be connected to your account and you will have to add it again, which if this doesn't fix the issue might be impossible.
