08-01-2022
17:17
17:37
08-01-2022
17:17
17:37
Need an option or an update to strengthen the vibration on the Versa 3. I've noticed that the vibrations seem to come from the top of the watch versus the Versa 2 could be felt at the wrist side of the watch. Things that would help would be a longer duration of vibration for text message and alarm notifications or a stronger pulse. Please and thank you!! ( Yes, my Fitbit has been restarted and yes it is set to strong vibrations setting)
08-01-2022 21:13
08-01-2022 21:13
Hi @StarLabTechJD - the Versa 3 doesn't have a strong vibration like prior watches, which is a shame.
Note also it gets weaker as the battery level falls.
If you are interested in testing the standard 8 vibration types try the SimpleVibrate app.
