08-06-2022
14:43
17:34
08-06-2022
14:43
17:34
Is anyone else having issues with their versa 3 band staying secured. I have talked to another person and they have had the same issue I have had with the band not locking in to place in the device.
08-07-2022 02:25
08-07-2022 02:25
Mine also does that on one side, the button won't snap into place like it is broken. I only had my Fitbit for 2 weeks.
08-07-2022 07:08
08-07-2022 07:08
Literally lost my versa 3 after falling into water while doing wakeboard with my watch on. Had bought it one week ago. So disappointed by the band quality. Isnt it supposed to be a watch you can wear while doing sport ?
08-07-2022 08:04
08-07-2022 08:04
When you say, staying secured, are you referring to the connection between the band and the pebble?
If so, try some alcohol and a q-tip to clean.
It worked for me.
