08-03-2022
08:57
17:37
08-03-2022
08:57
17:37
Hi Team,
Is there any way I can get my Versa 3 replaced?
Spring on the bottom latch won't come back up and it is getting hard for the band to stay in place because of this. I already tried applying rubbing alcohol on the latch however, it doesn't seem to do the trick.
Any recommendations?
Thank you.
08-03-2022 15:49 - edited 03-06-2024 07:41
Hi there, @latchb0i. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Please note that when a Fitbit device suffers damage while under warranty, you can contact Customer Support. Discounts and replacements depend on tracker model and other factors.
If you have any questions regarding what is covered under the warranty you can read more about it here fitbit.com/legal/returns-and-warranty.
Hope this information helps you.
03-10-2023 10:04
03-10-2023 10:04
I have the same trouble latch spring not holding an inserted band lower latch on my versa 3 also. Can it be repaired?
