I have the same problem. Distance is not correct. Steps, zone mins and calories burnt all appear acceptable. Your stats like mine are similar also. It's nuts. Annoyed. How to fix??
I noticed today that the only miles/distance recording & showing on the Today page are when I walk in the exercise app with GPS. Once I end the walk it no longer tracks distance/miles.
Hi Lude and all others with this problem and sorry that you are as disappointed and frustrated with Fitbit as I am.
I also have the same issue which first started on my Versa 3 date 23rd July 2024. I have now had 3 Chats and tried all of the possible fix’s including a full factory reset but problem still persists (also shows incorrect active mins and calories)
My case has been referred to Higher level support 3 days ago but unable to advise me when I will receive a response as apparently dealing with a lot of customer problems (I’m not surprised!)
I have been a very keen user of Fitbit for the past 6 years but had enough now given the decline in service and less than robust build and software. I will be surprised if any of us with this issue get it resolved.
Best AnswerHi Miguel
Hope you don’t mind me asking but you ever get this issue resolved? I have been having the same issue since 23rd July 2024 and Fitbit support seem unable to resolve the issue. My Versa 3 is only 17 months old but I believe faulty (yet again!)
Best AnswerI saw on another community forum that there are a lot more people with same problem. A moderator said they’re aware of problem. I also saw a temporary fix til the get problem solved. Go to your stride length & turn off auto & enter stride manually. I did this today & so far it is recording distance. Not sure how accurate but better than 0
Best AnswerHi there, yes I have done all of the above and also did the factory reset. It took hours. I even went to sleep and woke up in the middle of thre night and it was still resetting. Anyway, I woke up the following day after all aforementioned this was over a week ago - and there was absolutely no change at all. I did 25,408 steps on Saturday night (18/8/24) and remarkably i did all of this in only 5.06km! I am at present still wating for a resolution.
Best AnswerShort answer - NO. Nothing has changed at all. I have done all of the above and also did the factory reset. It took hours. I even went to sleep and woke up in the middle of the night and it was still resetting. Anyway, I woke up the following day after all aforementioned (this was over a week ago) - and there was absolutely no change at all. I did 25,408 steps on Saturday night (18/8/24) and remarkably I did all of this in only 5.06km! I am at present still wating for a resolution.If you dont set your entire day on an "exercise" - e.g walk, workout, run etc. You will recieve a big fat zero 0.0km distance covered, everytime.
Best AnswerIt didnt work out very well did it.
Best AnswerI have already done this. There was nothing wrong with my stride length. I still get zero distance covered.
Best AnswerHi Gazdog, yep.. here we are again. I haver had this problem since 9th July 2024. It would be really nice if they fixed this soon wouldnt it?!!
