10-08-2025
06:30
06:05
10-08-2025
06:30
06:05
My new versa 3 is counting steps I havent done and logged an activity that I went for a walk at 12am when I know I was sleeping! How can I fix this? Ive done a reboot of the versa but no change
10-09-2025 06:04 - edited 10-09-2025 06:05
Hi there, @Ilh. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear about the oversteps count. I understand your concern, I will do my best to help you with this!
Before we can work on this together, could you confirm if you have MobileTrack connected to your account? MobileTrack is a function that allows you to track basic information using your phone's sensors when a Fitbit device isn't nearby. If this is correct and there was a fan or something buzzing nearby, you might get extra steps as this function might think you're exercising.
Assuming this applies to you, I'd recommend removing this function from the Fitbit app and monitoring your watch's behavior afterward. For instructions on how to remove a device, see this help article.
On the other hand, I was wondering if you're wearing your Versa 3 while sleeping or you take it off? If you remove your Versa 3 (or any other Fitbit device) and lay it face up on a reflective surface it may detect the flashing LED and produce "ghost" data, sometimes steps or HR. Try lying it face down (and on a non-reflective vibration-free surface).
If you want to negate the extra steps, see How do I add, edit, or delete Fitbit data and activities?
Last but not least, keep in mind the algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or performing other activities with arm movements, a device on your wrist may add some steps. When you’re doing activities that involve arm movement, such as working or cooking, you often walk a few steps in-between stationary periods as well, so the device tries to give you credit for those steps. For most customers, the number of extra steps added by arm-based movement isn’t significant when compared to your overall stats. For more information, see How accurate are Fitbit devices?
Best Answer10-09-2025 06:04 - edited 10-09-2025 06:05
