06-12-2024 08:11
06-12-2024 08:11
I was using SpO2 signature clock face on Versa 3 that was replaced. Setting migrated over and new Versa is on same account. But I clock face didn't migrate and I cannot find it when searching clock faces.
06-12-2024 21:17
06-12-2024 21:17
Hi @jims22 - if you just replaced your watch it may not be fully updated yet.
In watch Settings, About Versa 3, System info see firmware level. The latest is XX.128.6.17
If you aren't at that level it will come as an update in a few days or you can do a factory reset (not without risk) to get the latest version.
However as the watch will get SpO2 by default (with the right firmware) you may want to use a more useful clock face. You can still check the single night's value from the Today app on the watch and in health metrics in the Fitbit App.
That way you can select far more useful clock faces which show values that change during the day.
Best Answer06-13-2024 14:08
06-13-2024 14:08
My versa 3's firmware is 36.128.6.17
When searching for spo2 clock faces in the app only two others show up. One doesn't show SpO2 and other has numbers that are too small.
I prefer the SpO2 signature clock face since the % is right there by a quick tap or two.
And I can also see steps etc with a tap without my reading glasses.
Best Answer06-19-2024 06:13
06-19-2024 06:13
The SpO2 clock face appeared yesterday. Maybe it takes up to a week for account to see available clock faces after firmware is updated.
