12-30-2020
12:05
20:50
12-30-2020
12:05
20:50
Just got a new versa 3, worked great for about a week and then this morning the pin number for the fitbit(tried to setup the wallet feature(my bank was not supported in the end) and it required me to add one) suddenly stopped working.
I type in the correct pin and nothing happens, the screen times out and goes black but I am unable to use the touchscreen. If I press the butting on the fitbit it takes me back to the home watchface but then if I try to swipe to another function the pin screen pops back up. It doesn't do anything different whether it type in the right pin, or the wrong pin, the same thing happens. I cannot restart my fitbit because it has to be done through the watch itself, and I cannot change the pin or anything because within the app the "device lock" option won't open and gives me the error message:
"Error registering versa 3 with Fitbit pay wallet
Error connecting to versa 3. Make sure it is close by and turned on."
The fitbit still syncs data but I just cannot use any of the functionality. Please help.
12-31-2020 00:42
12-31-2020 00:42
You could try restarting the fitbit by pressing and holding the button for around 10 seconds until the logo appears.
01-21-2021 12:09
01-21-2021 12:09
@SteveH your help is appreciated. Hi @Tyklein1, welcome to the Community Forums.
@Tyklein1 thanks for sharing those details about your Versa 3 situation. According to the Support team you are already in contact with them about this. Please follow their instructions and reply back to them so you can receive help.
See you around.
01-06-2022 01:14
01-06-2022 01:14
What was the resolution for this, I am getting the same?
I can sync my Versa 3, but it's locked. When I try to use the device lock function within the app and set a new pin I get Error connecting to Versa 3 message.
At this point it's been like this for weeks.
01-06-2022 01:27
01-06-2022 01:27
