04-12-2022
09:39
20:02
04-12-2022
09:39
20:02
Please help… back button was unintentionally held in earlier as I was leaning on something and now the fitbit logo is stuck on my Versa 3 screen. Tried holding the button in until the screen resets but then then logo just reappears. Seems to be a common problem but what is the solution? Thanks in advance 👍🏼
04-14-2022 04:49 - edited 11-13-2023 04:10
Hi there, @EckHar. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
If you haven't done so yet, please try the following steps:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
Best Answer04-14-2022 04:49 - edited 11-13-2023 04:10
Hope this helps.
