08-21-2022
13:00
17:25
08-21-2022
13:00
17:25
Stuck on logo, tried all the self help advice but it’s still stuck on the logo
Hi there, @Jonnieg. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
To better assist you, may I know the steps you've performed so far? In the meantime, please confirm that you've tried the steps below:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
Best AnswerI am having the same issue. I press the side button and held down for 10 seconds it rebooted the watch, however the Fitbit Logo is still on the screen frozen. I have turned off bluetooth on my phone, still nothing. Just seems if I can't get the watch off the logo, will it connect at all. Your instruction above just sound like a lot to go through. This is the 2nd Versa 3 I've had in two years with issues.
Best AnswerWhat do you mean by "force quit" the Fitbit app?
I've tried the steps above and the watch will not reboot at all.
