11-19-2022
02:05
16:58
11-19-2022
02:05
16:58
I have a versa 3 Fitbit....which after using restart will no longer switch back on...it just shows Fitbit logo and then turns off....
Hi there, @Donric2202. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please note this issue comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed (or making sure you've done them as instructed):
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hi there, @Kennisgre. Thanks for stopping by in the Community Forums. I appreciate you had followed the tips and recommendations provided above.
As our last resort, I suggest to perform a factory reset by following these steps:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Best AnswerI have attempted the steps below several times with no success. Please advise how I can go about getting this replaced. Thanks!
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
