10-09-2023
10:44
15:22
10-09-2023
10:44
15:22
Hello!
My fitbit is stuck on the logo. I did try to reset, nothing happened, it stayed on the logo. I let the battery drain, then charged it, still it was stuck on the logo. I went to a cellphone store today and they said that they will need to open it but then the screen might crack and it would be hard to replace. What can I do? I have even put it in rice for if it maybe got water somehow. I never put it solemnly under water.
10-10-2023 15:24 - edited 10-10-2023 15:24
Hello there, @Kara6. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post and your time in trying to troubleshoot it before reaching out.
If you haven't done so yet, I'd recommend trying the following step sin the order listed:
With the steps above, what I want you to do is to pair your Versa 3 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer10-10-2023 15:24 - edited 10-10-2023 15:24
