08-02-2022
07:47
17:37
08-02-2022
07:47
17:37
When I got up this morning my fitbit versus 3 said I had 21000 steps, this is the 2nd time this has happened in about 6 months what's going on?
08-02-2022 08:50 - edited 10-07-2024 05:50
Hi there, @gralishjc. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 3. I understand where your concern is coming from.
I'm wondering if you're using another app connected to your Fitbit account that will add more steps? Mobiletrack maybe? Low-power step sensors inside your phone track your steps and send the data to the Fitbit app. We recommend using MobileTrack if you forget your Fitbit device at home.
Note that adding more than one Fitbit device to your account gives you the convenience of switching between devices while still seeing a holistic view of your daily activity on your dashboard.
If you want to negate the steps tracked while you were sleeping, see How do I add, edit, or delete Fitbit data and activities?
As a friendly reminder, please note that Fitbit devices have a finely-tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or performing other activities with arm movements, a device on your wrist may add some steps. When you’re doing activities that involve arm movement—such as working or cooking—you often walk a few steps in-between stationary periods as well, so the device tries to give you credit for those steps. For most customers, the number of extra steps added by arm-based movement isn’t significant when compared to your overall stats. For more information, see How does my Fitbit device calculate my daily activity?
Hope that helps.
Best Answer08-02-2022 08:50 - edited 10-07-2024 05:50
Hope that helps.
Best Answer08-02-2022 11:08
08-02-2022 11:08
This happened to me yesterday and no, I don't have anything else connected to my Fitbit app. When I woke, I had done over 6,800 steps.
Best Answer08-02-2022 12:12
08-02-2022 12:12
No I did not have anything else connected to this fitbit app it was on the charger all night so it never moved and when I get up there was 21000 steps on it.
Best Answer08-02-2022 16:33 - edited 11-16-2023 11:03
Hello, @DudleyDavies. Thanks for stopping by in the Community Forums.
@gralishjc @DudleyDavies I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
