04-21-2023
08:05
07:31
04-21-2023
08:05
07:31
Hi all. I've been using my partners old charger 2 since he went to an apple watch to track my work outs and steps.
I'd like to upgrade to the Versa 3 but I couldn't tell from the blurb if it showed you your WhatsApp messages?
Also, can autosync be turned off? The charger 2 is killing my phone battery and I'm having to disable the Bluetooth, and so the app, to stop it dropping like a 5 year old phone every day.
Thanks x
Hi @FlissJS - the Versa 3 can display any notifications, including WhatsApp, that show on the phone's status bar.
However there are some setup issues if you have an iPhone but it's not a problem with Android.
As regards battery draining, are you sure it is the Fitbit App that is to blame, in the meantime you can always turn off phone's location [which can use phone battery] and may still get notifications but it won't be able to sync until you turn it on again.
Consider the 3 in preference to the 4.
There may be some issues with the phone or phone settings, depending on the phone, that a logout of the Fitbit App and restart of both devices may resolve.
