11-03-2022
07:07
17:02
11-03-2022
07:07
17:02
My Fitbit worked fine yesterday and was charging correctly when I went to bed. I pulled it out of the charger this morning and it seems completely dead. Nothing I've tried has worked. Any ideas?
11-04-2022 04:08 - edited 03-15-2024 15:43
@RiverRunner7 Thanks for the details provided.
As per the description of your post, I suggest trying the following:
@mramlm Thanks for stopping by and sharing the details about your Versa 3's behavior. I appreciate your time and efforts in trying to troubleshoot the issue with your Fitbit device.
As recommended above, if the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
11-03-2022 11:29 - edited 03-15-2024 15:43
Hi there, @RiverRunner7. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
To better assist you, would you mind sharing with me which steps you tried so far?
In the meantime, please restart your Versa 3 as instructed here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work, please let me know if you feel a vibration while performing the restart.
11-03-2022 13:22
11-03-2022 13:22
Thanks! I've tried holding the button down but nothing happens. No vibration. The screen is black and it won't turn on. Is was 23% charged last night when I put it in the charger and 67% charged the last time I checked. Next thing I knew it was off and won't turn on.
Best Answer11-03-2022 14:19
11-03-2022 14:19
Mine is doing the same thing. When I go to restart it, the screen flickers briefly then goes back to black. I have an alarm set for 8am, it vibrated but the screen remained black.
Best Answer11-04-2022 04:08 - edited 03-15-2024 15:43
