08-01-2023
14:35
07:16
08-01-2023
14:35
07:16
I have tried the troubleshooting for my versa 3 bit it still will not sync with my watch. What else can I try?
Hi, i just had this issue. i contacted customer support for it. mine had the day and time way off they said to restart my fitbit, which didn’t work for me (to restart it you hold the bottom right and the left button at the same time until it turns off) then we tried a whole bunch of things and the only thing that worked was to update my fitbit app (if i knew it was that simple i wouldn’t have contacted support) i hope this helps
Hi there, @Robin9165. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
In addition to the steps you've tried, please attempt the tips and recommendations provided by @brooklyn234. If the issue persists, please try:
With the steps above, what I want you to do is to pair your Versa 3 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
@brooklyn234 I'm glad to hear that you're back on track! 🙂
