I think the battery does pick up, but not a large amount. 3 days is not too unreasonable, depending what you are using. 4+ days as stated in the advertising is under basic use. If you have a watch face that uses a lot of power, all day sync turned on, use GPS, or look at it frequently you wont get as good a battery life.
I'd suggest you try restarting the Versa a couple of times and see how you go taking the points above into consideration.
Helen | Western Australia
