04-05-2019 07:03
04-05-2019 07:03
Is there a way to change the color of the background with the new Bitmoji update? Mine is currently blue, but I see black, orange, purple and green as other options under the "See all details" link. How do you change the background?
04-07-2019 15:52
04-07-2019 15:52
Hi, go to Clock Faces and press it. You will see "My Clock" . Press that and you will see on the bootom left side of the screen "stettings". Press that also and search for changing background colour and, when found, change it to the color you like. After changing the background color of your Clock Face, you have to press the back button and press "Ready" or "Done" on top of your screen on the right side, otherwise your watch will not change the background colour.
Best Answer04-05-2019 09:32
04-05-2019 09:32
Hi, in the dashboard of your Fitbit app, press the watch icon on top of the screen on the right side. You'll see the page with Clock Faces, etc. Press Clock Faces. On the left side you see your current Clock face. Press your clock face and if it's adjustable, you should see on the bootom of the page on the left side: "settings" and "details". Press settings and look for background color and choose the color you want. Then press the back button and press on top of the screen on the right side "done".
04-06-2019 16:43 - edited 04-06-2019 16:52
Hi, thanks for the vote, but if my suggestion solved your problem, see my signature and mark my first post as an accepted solution so other users with the same problem benefit from it. Thanks in advance.
Best Answer04-07-2019 15:29
04-07-2019 15:29
When I was setting up a few minutes ago, a background color option was there. I chose a color, but after installation, the clock face still had the black background color. I followed your helpful hint, but background color was not listed in my settings. Is there another way to do this? I can't find anything else about this topic.
Thank you for any help you can provide.
Best Answer04-07-2019 15:52
04-07-2019 15:52
Best Answer04-07-2019 15:56
04-07-2019 15:56
Best Answer04-07-2019 16:03
04-07-2019 16:03
That's really weird. Normally when you have installed a Clock Face and it's completed and showing "settings" and "permissions", you also should see that when you want to adjust your Clock Face afterwards. So, go to Clock faces and in the tile of My clock, press the clock image itself and it should show you "settings" and by pressing that, you should be able to change the backgrounnd color. For the rest, see my earlier post.
Best Answer04-13-2019 15:47
04-13-2019 15:47
Best Answer04-13-2019 16:08
04-13-2019 16:08
Hi, I have a suggestion for you for a beautiful Clock Face, which is not only highly customizable but also small in size and therefore very battery friendly. Although it's a payed Clock face (only $1.1 after a trail period of 30 hours) I think you will find it a gorgeous one: The One Digital by azara. It has a two screen interface, the Home display, which you can adjust to your own liking and, by tapping on the home display slightly the "stats screen" , showing you immediately the following stats: HR - Steps - Calories - Distance - Active Minutes and Floors. This stats screen is much, much faster tha the Today Screen will ever can/be. Just try it for 30 hours and I', convinced you will buy it after that time. My Versa lasts almost 6 days with this Clock Face.
Best Answer04-13-2019 16:27
04-13-2019 16:27
Best Answer04-13-2019 16:29
04-13-2019 16:29
You too!!
