05-30-2019 07:03
05-30-2019 07:03
All data on display shows zero value. Clock is accurate. Fitbit is tracking steps, heart rate etc. and reporting under daily activity. I have reset with no effect.
05-30-2019 09:13
05-30-2019 09:13
Sometimes clock faces developed by non-Fitbit encounter problems.
If you have changed clock face, it's worth a try to switch to another clock face, safest bet a Fitbit one. If a Fitbit clock face works, then you know it was a problem with that clock face, and you could try others if you want.
