04-17-2020 08:26
04-17-2020 08:26
Hey guys,
I'm a loyal fitbit customer bought my Fitbit Versa in December 2018, after having a Charge and Charge 2, and never had any issues! However, now the HR (Green light) Infrared isn't working and the Versa is not picking up any HR info.
It had been working sporadically on and off the last few weeks, and once I shut it down it would work again for a few hours. I have performed the shutdown, as mentioned by other users, AND a factory reset to no avail. Any tips on how I can get this to work again?
As I'm on specific medication, I and my Dr rely on the sleep information provided by my Fitbit to monitor my sleep pattern so it's rather important I get this sorted soon.
Thanks in advance all 🙂
04-17-2020 09:02
04-17-2020 09:02
Hey girly! I’m having the same problem! I’ve tried resetting mine, charging it, turning the heart rate on and off through my versa settings no luck. How do you do a factory reset?
Best Answer04-17-2020 09:15
04-17-2020 09:15
Hey Kimberly, if you open the Fitbit, go on to Settings in the app > About > Factory Reset.
Just remember to sync it before as it will erase all the data and good luck 😞 Hope you sort it!
Best Answer04-17-2020 09:23
04-17-2020 09:23
I am experiencing the same issue. I've done the soft reset and the factory reset and nothing is working. So frustrating. If you find a fix. Please let me know 🙂
Best Answer04-17-2020 17:14
04-17-2020 17:14
I keep reading this is a common issue with the Fitbit Versa and nothing you can do to fix it unless it’s under warranty. Mine isn’t as it’s a year and a half old 😭
Best Answer04-17-2020 20:15
04-17-2020 20:15
Ugh that’s unfortunate. Wish I had known that this would be an issue down the road before spending over a hundred bucks on it 😞
Best Answer04-18-2020 06:13
04-18-2020 06:13
I know right! It's so frustrating after only a year and a half and the HR goes bust. What's the point of having the watch if i can't monitor HR during sleep, or during exercise?
