11-06-2018 03:13
11-06-2018 03:13
How to you make the Heart Rate numbers larger on my versa Watch. ? It is too small now and can't read it during exercise classes. It must be a setting I am sure . But I do not know how to do it. Thank you
Best Answer11-06-2018 10:58
11-06-2018 10:58
Hello @tannenbaumb if your referring the the heart rate on the stats section then @NellyG is correct.
If your referring to the heart rate on a clock, you would need to change the clock face.
11-06-2018 05:13
11-06-2018 05:13
Sorry, there is no setting to make it bigger. I agree the figures are hard to read without glasses.
Helen | Western Australia
11-06-2018 10:58
11-06-2018 10:58
11-06-2018 11:05
11-06-2018 11:05
@tannenbaumb you're mentioning heart rate numbers during classes, so I'm assuming you're exercising. If you start a workout on your versa directly, you will be able to tap through middle stats to the heart rate. Middle stats are huge numbers. Hope that helps.
11-06-2018 11:07
11-06-2018 11:07
