01-21-2021
01:09
03:54
01-21-2021
01:09
03:54
Hi, I'm really having no luck with this product!
I purchased a versa lite yesterday and at 3am i took it off the charger and put it on. I have kept it on pretty much all day but by 8pm it is down to 68%. At this rate it wont last a day and a half!
Nothing works on it so it isn't like I'm doing more than having the basic stats running and checking the time.
Best Answer01-21-2021 03:55 - edited 10-20-2023 15:20
Hi there @Evelle, welcome to the Community Forums. We‘re taking into consideration your comments and sentiments with regards to our products and services.
Versa battery should last up to 4 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or animated clock faces. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
