09-25-2019 05:06 - last edited on 09-26-2019 12:59 by LiliyaFitbit
I am looking for a simple clock face. Just need the time & date (Wed/9/25). Nothing that will drain the battery. I tried the FitBit Emoji which was great just drains the battery. I am now using the picture one, but it doesn't have the day (Mon). Can anyone give me options?
Best AnswerHi @SolieMe, it's nice to see you again in our Community Forums.
I appreciate your participation in the Forums and sharing your concern about selecting the clock face for your Versa Lite which doesn't affect the battery life. I personally use at the moment Grad Times clock face and it doesn't impact the battery life. As animated clock faces may require more frequent charging, I recommend selecting a Fitbit clock face.
I also recommend restarting your device and checking the additional tips to prevent battery drain in this help article: Can I extend my Fitbit device's battery life?
Hi, I do not know if the following CF is available For the Versa Lite, but the CF Minimal Style comes closest to your wishes. It shows date -time - stats on the home display in a size of only 8 kB, so very very battery friendly. It's a Third Party One CF, so tap CF's, than all CF's and search for this CF. It's also highy customizable regarding colors, etc. Hope it's compatible with you Versa, cause I use it myself and my battery drainage is only 10% per day. Regards kuzibri
Hi @SunsetRunner, thank you for joining this thread.
I appreciate your participation in the Forums and sharing your experience and suggestions. I am sure your tips will be helpful to other users.
Thanks for stopping by, see you around.
