02-06-2020 10:21
02-06-2020 10:21
My Versa lite keeps losing time. Yesterday I did a factory reset, removed Bluetooth deleted the fitbit app, rebooted my phone and did an update that took over an hour. This morning it was twenty minutes behind, then after I re synced my phone, it fixed up time. It has been like this for well over a week, every night. I use my versa as an alarm, so this is getting very frustrating.
02-09-2020
15:25
08:01
02-09-2020
15:25
08:01
Hi @Hippypippa, it's nice to see you again participating here in the Community Forums, welcome back! Sorry for the delayed reply.
Thanks for bringing this to my attention and for troubleshooting your device prior to posting, I totally understand how frustrating this matter can be for you. Let me share with you that our Fitbit devices use your mobile device information to display the time with the syncing process, therefore, by simply syncing your Versa Lite it should display the time that's configured on your Android mobile device.
However, this may also be fixed by updating the time zone setting in your Personal Settings. For step-by-step instructions, please see our help article: How do I change the time on my Fitbit device? and let me know how it goes.
I'll be around, let me know if you have any additional questions.
Best Answer02-09-2020 20:30
02-09-2020 20:30
Hi. I reset the time to another country last night then changed it back. Time was wrong again this morning. I have had this device for 12 months and have never had this problem before. I have sync on all day. It has always synced without issue.
Best Answer03-07-2020 04:23
03-07-2020 04:23
I’m having the same problem but it only started March 1, 2020. It is thoroughly aggravating, I’ve done all the recommended repairs but it keeps happening.
03-07-2020 15:04
03-07-2020 15:04
I had this problem not long ago and It ended up being a clock face issue. I used the bitmojie face for months and all of a sudden it started losing time. I tried everything and it kept happening. I changed to another clock face and havnt had an issue since. Its worth a shot if you havnt tried it yet.
03-07-2020 15:50
03-07-2020 15:50
I tried everything that was suggested, but nothing changed. Fitbit have now replaced the watch. Not the bands or charger, just the fitbit itself.
Best Answer03-07-2020 15:52
03-07-2020 15:52
I never changed the clockface from the one it came with. It seemed to be more of a Bluetooth and syncing issue. Fitbit have sent me a replacement.
03-08-2020 17:18
03-08-2020 17:18
Best Answer03-08-2020 17:19
03-08-2020 17:19
Best Answer03-09-2020 05:58
03-09-2020 05:58
Best Answer03-09-2020 14:52
03-09-2020 14:52
I took lots of photos of the wrong time next to a clock, and sent them through to support. Did everything that they wanted me to, then they advised that they would replace. Didn't replace the whole Versa Lite, just the actual device, retained old bands and charger.
03-09-2020 19:52
03-09-2020 19:52
Best Answer03-10-2020 09:53
03-10-2020 09:53
Best Answer04-28-2020 11:38
04-28-2020 11:38
I have been experiencing the same issue for nearly a month. It won't sync until the battery dies and I charge it again. But it starts losing time as soon as I take it off the charger. I have unpaired it, deleted and reinstalled the app, restarted the device, and followed every suggestion listed in the help section. Nothing seems to cure the problem.
Best Answer04-30-2020 14:26
04-30-2020 14:26
this just started for me as well yesterday with 30 minutes behind. Did all the above. Unpaired, Uninstalled app. Paired again (that was a booger) reinstalled app, finally, got it to work. Noticed this morning it was 2 minutes behind. By noon, 10 minutes behind. Now, 20 minutes. I've rebooted phone, and device, and last sync was at 9:26 this morning. I changed time zone to Africa, then back to my time zone, and tried to force sync it but won't sync. Said device not found. Restart devices, try to sync, but has a pink exclamation point. I was given this as a gift 9 months ago. Whats up with this?
08-07-2020 17:12
08-07-2020 17:12
Daughter has done everything above that's been suggested. Trying to change the bitmoji ckock now but doesn'twant to connect. It won't sync but once a day, sometimes 2x a day. Have had over a year and just now having trouble this last week or so.
10-02-2020 07:46
10-02-2020 07:46
Mine is also losing time I have changed time zones I have done all the above and nothing has worked.I am now 2 hr and 20 mins behind my time . Yesterday it was a hour and something
Best Answer11-16-2020 08:23
11-16-2020 08:23
This is Exactly my issue also. Every night I lose 20 mins of Time I Too reset and repaired yet I woke up to the Same Problem. I haven't even had mine For A Year YET I am very frustrated and unhappy
Best Answer11-16-2020 08:27
11-16-2020 08:27
YES Same had mine For about 7 months and Every Night I lose 20 mins. I am so Frustrated. I have also done All the above steps. FitBit Geniuses please Help US ASAP
Best Answer12-11-2020 05:15
12-11-2020 05:15
I've just started having the same problem. They've replaced mine once after I had it a month. I'll have to get on the chat when I have some time and go through the process. Mine only happens at night. Right now it's almost an hour behind. I get notifications and everything else seems to work but the clock isn't right. At some point after many failed sync attempts suddenly it matches my phone. I don't know. I'll try to see if they can help.
