08-19-2020
18:29
10:51
08-19-2020
18:29
10:51
As the subject line indicates this is my THIRD device and SECOND replacement of the Fitbit Versa Lite. The issues I am having with the current device is as follows:
Hi there @CrystalDavisWil, welcome to the Community Forums. I'm sorry to hear that you're going through this situation with your Versa Lite replacement. I appreciate you took the time to try fixing the screen, heart rate, and battery of your watch prior to posting here, I'll be glad to continue assisting you.
As per the description of your post, it seems that your watch may have insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub. Please note that for best results, don’t leave your device plugged in on the charger longer than overnight.
If you haven't done so yet, I suggest taking a look at this help article: Can I extend my Fitbit device's battery life?
On the other hand, if you have charging difficulties, please check the steps below:
About the heart rate that stopped working, I'd like you to please confirm that the heart rate settings on your watch is "On". On your device, open the Settings app > Heart Rate > tap to turn the setting On.
If the heart rate is On, I'd recommend trying the following steps:
The restarts recommended above should also help with the screen that is randomly flashing.
Hope this helps. I'm looking forward to your response, keep me posted.
Hi there @CrystalDavisWil, thanks for the update. I appreciate you have already tried to troubleshoot this situation before reaching us. At this moment, I’ve reached the limits of what I can do for you here on the public community forums, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon. 😉
