08-29-2023
07:20
08:39
08-29-2023
07:20
08:39
My watch is not syncing. I’ve turned it off and back on. It loses 3 minutes each time this is done. I’ve deleted the device from my Fitbit device. It aborts every time I try to set up new device. It is a versatile lite, I think.
Moderator Edit: Clarified subject & Personal information
Hi there, @DanRR. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out.
According to your post, it seems like your Versa Lite is not syncing. With that being said, please try the following steps:
With the steps above, what I want you to do is to pair your Versa Lite first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Once you manage to sync your Versa Lite, the time should be corrected. Keep in mind that your Fitbit device uses the time of the device you're syncing with.
Best AnswerI have done this 2 times a day for the last 3 days! And it’s back at again today! This does not fix the problem! So now what?
