08-13-2022
06:17
14:57
08-13-2022
06:17
14:57
My Versa Lite had a blank screen this morning. Looked into it & it said it needed updating, well its been updating for over an hour now so I have a feeling it will never say update complete. Anyone else had a problem with it ? Also when asked which model it is Versa Lite does not come up, just Versa 3 which I believe is a different model, am I correct. I have also had to change my email as I got a warning that I was using the same email for another website which I never use anyway.
Update: I will reply to myself. My Versa Lite finally did update itself, only after I turned the bluetooth off on my other devices ( something I read in the thread)
Best Answer08-13-2022 15:02 - edited 07-16-2023 03:44
Hi there, @GH_22. Welcome to the Community Forums. I'm glad to hear that you were able to update your Versa Lite at the end. Thanks for sharing the steps that worked for you. 🙂
In you need help in the future with the same topic, please see Why can't I update my Fitbit device?
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
I've moved your post to the Other Versa Smartwatches board for organization purposes.
