So many VERSA questions... trying to figure them out myself. However, could use some help with the following:
1.) How can I change the clock face?
2.) I do not want to get text messages on my Versa. Is there a way to turn this off?
Thanks... and Happy New Year from Charleston, South Carolina. 🐝
Best AnswerHi,
1. to change the clock face, press the Versa icon on top of your dashboard on the right side. It will bring you to a new page in which Clock Faces are present. On the left side you will see "your clock" and on the right side "All Clocks". Press that and scroll to all the avalaible clock faces, choose one you like by pressing it and click install. Some clocks show after installing (after a few secs the installing ended) setings and permissions. Enter settings and customize it the way you want. Enter permissions and enable them all. Ready.
2. Regarding receiving notifications: on the same page as the Clock faces are, scroll down untill you see "notifications", press it and you'll see a list of possible notications, which you can disable. To be sure that they will be disabled go to your Versa, press the left button and hold it for 2 secs and you will get the socalled activity screen. There are two items on that screen: Display and notifications. Set the last one, when it shows enabled to disabled by pressing it. Then go to the settings of your Versa, scroll down to notifications and see whether they are off during the day and night. Ready. Good luck.
Best AnswerHi,
Best AnswerThank you so much for your response.
One thing forgot to tell you is this:
I'm an idiot.
#KiddingKinda
I'm attaching a pic of my dashboard.
I do not see a "Versa icon on the top of my dashboard on the right".
Geez... what am I missing?
B🐝
Best AnswerHi, nobody is an idiot. I assume that you have the Fitbit app installed on your Mobile Device. Once you start the app, a dashboard will be displayed showing your steps, acitive minutes, etc. On top of that screen on the right side you see the icon of a watch, with directly right next to it your battery icon. That's the Versa icon I meant.
Best AnswerHi, congrats with getting the "marked as a solution", but am I missing something? It's my understanding that I solved your problem, but never mind.
Best AnswerYes!
You absolutely are the one who answered my question
and solved my problem.
Hmmmm... something wrong?
@SunsetRunner wrote:Hi, congrats with getting the "marked as a solution", but am I missing something? It's my understanding that I solved your problem, but never mind.
Best AnswerI thought I DID mark you as the solution...
See I told you I was an idiot.
Please tell me what I did wrong and
how to correct my mistake.
Thanks.
Best AnswerHi, possibly you accidentaly pressed the wrong post, e.g. in this case yours, as "marked as a solution". This is something that happens sometime. As you can see, it's already corrected by someone else. For the future: if you want a post to "mark as a solution" press on the post from the one who replied to your question as to your satisfaction. No worries my friend, isn't a big issue. Anybody can make a mistake, nott only idiots "lol".
