12-23-2018
20:38
08:29
SantiR
12-23-2018
20:38
08:29
SantiR
Just got a new fit bit
Fitbit says 1755 steps dashboard says 1243
whats up with that
Moderator Edit: Updated Subject for Clarity
12-24-2018 00:50
12-24-2018 00:50
@Bandybroad the dashboard shows the total as it was when it last synced, the fitbit will always show the true total. Could it be that you just haven't synced for a while?
12-24-2018 11:03 - edited 12-25-2018 08:30
@Bandybroad Welcome to the Fitbit family! I moved your post to the Versa Board as there are more chances for you to receive an answer to your inquiry here. Thanks for posting the situation you are experiencing with the difference in the steps shown on your device and your dashboard.
Just as @SteveH shared, this could be happening as a result of not syncing your Fitbit device. Please try syncing it. If you are having trouble to sync; please follow these syncing troubleshooting steps in order to sort that out.
Hope this helps. Keep me posted!
12-24-2018 14:43
12-24-2018 14:43
12-25-2018 08:26
12-25-2018 08:26
@Bandybroad Thanks for your reply and for sharing all of those details regarding the experience you are having with your Fitbit watch.
It is not needed to put the watch on the charger to connect it to Wi-Fi. Please feel free to check this helpful article for more details.
You can only sync using one device at a time. Please check if the iPad you are using is compatible.
Yes, you can sync with the app while away. Just make sure you have internet connection on your phone and Bluetooth. Check this helpful article for more details on syncing.
If you happen to experience trouble to sync; follow these syncing troubleshooting steps in order to sort that out.
12-25-2018 08:32
12-25-2018 08:32
