02-18-2019
10:56
16:33
SantiR
02-18-2019
10:56
16:33
SantiR
I resisted updating my versa firmware seeing how many problems it was causing but I finally did it since if it bricked my versa I wanted to be able to replace it under warranty
no surprise to me now that I have the new firmware and an running the latest version of the android app connection is completely unstable... the versa is basically useless during runs b/c it just keeps saying "connecting" for 95% of the run. I have restarted bluetooth multiple times and restarted the versa
dear fitbit when are you going to fix these issues that have been known for ages? I paid good money for a device that you keep making worse with every "upgrade"
Moderator Edit: Updated Subject for Clarity
Best AnswerHi @fueledbycoffee. So sorry to hear about your issues. I’ve asked a moderator to step in to help since I’m not sure what to do. I’ve not had any problems with my firmware updates. You should be getting a response in the next day.
BTW, I like your user name and at times can definitely relate.
@fueledbycoffee I hope you're doing well! Thanks for taking the time to share the situation you are experiencing with your Versa after updating it so far. Thanks for trying those steps in order to sort this out.
I went ahead and created a case with customer support in your behalf for you to get further assistance on this. Please keep an eye on your email inbox for next steps.
@SunsetRunner Thank you very much for calling this out!
Keep me posted!
Ha I can only laugh b/c otherwise I would cry
I have been dealing with support. I sent them a GPX file from another app to show that the issue is fitbit app software not my phone GPS and they don't know how to open a GPX file.. Support for a company that makes fitness watches with "GPS capability" is unable to open a GPX file. I even told them they could open it in strava or runkeeper.. I told them how to open it and they don't know how to open it..
Anyways I got a "please mark a solution as accepted" email - no.. no there is no good solution b/c support isn't remotely capable to helping b/c they don't even know how to open a GPX file!
