Unfortunately, at this time Fitbits are not set up to text. The quick response is set up for typically used responses but not for sending texts as you go. There is a suggestion for this on the Feature Suggestion forum here which you can vote for to try and get it implemented. Or you can create your own suggestion on the forum.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
