03-22-2021
15:52
05:21
03-22-2021
15:52
05:21
My versa isn't holding a charge, battery life is only about 10 hrs at most
03-23-2021 05:22 - edited 03-23-2021 05:23
Hi there, @Babyandy01. Welcome to the Community Forums. Thanks for the details provided in your post.
As you may know, your Versa battery should last up to 4 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or animated clock faces. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
I've moved your post to Other Versa Smartwatches board for organization purposes.
Hope that helps.
Best Answer03-23-2021 05:22 - edited 03-23-2021 05:23
Hope that helps.
