Versa battery issues
Hi there does anyone have the same issue as me? I charge my Versa using the docking station once the versa displays 100% fully charged I remove and place on my wrist. I then check the battery level and it has already reduced to 99%. Is this normal?
2 REPLIES 2
Hi, yes this is normal. I have that too all the time, so don't worry about that. the Versa should last 4+ days on one charge.
Hi there thanks for your reply.... I've only had my versa for a month so was a bit concerned that there was an issue.
