10-04-2018 14:25
10-04-2018 14:25
10-04-2018 14:47
10-04-2018 14:47
I'm here for the same reason. I bought mine on 8/15/2018, so 7 weeks ago. I made full use of it's features and would get about 4 days of use between charges. Then, starting about a week ago, it only lasts about 24 hours. I've even tried the steps for extending battery life such as disabling several features and turning off all day sync, that gave me about 25 hours before it turned itself off due to low battery.
10-05-2018 12:36
10-05-2018 12:36
Hey guys! Welcome to the Community!
@brian_g05, I appreciate you have taken the time to disable some of the features from the Versa to make it's battery last longer. Since the issue persists, I have escalated your case to our Support team so they can further assist you. So keep an eye on your inbox.
@Jbett01, thanks for trying the last longer battery tips. Since the issue persists, and considering that you just bought the Versa, maybe you can go to the retailer and ask for another Fitbit Versa, as the battery of this one might be defective.
Let me know how it goes!
Best Answer10-05-2018 16:50
10-05-2018 16:50
I am having the same issues. Worked great for a month with no issues (all features on and battery life was 3 to4 days). Last week for some reason the battery life is down to 22 hours. Nothing was changed on the watch or the app. Let me know if there is a solution or just a bum watch.
Best Answer10-05-2018 20:16
10-05-2018 20:16
I am having the same issue. I purchased mine the end of July. It worked good with all of the bells and whistle’s going. Now I’m getting about 10 to 12 hours maximum, no different settings.
Best Answer10-06-2018 12:47
10-06-2018 12:47
Hey guys, @Raelrea and @Firejohn, welcome to the Community! If the battery of your Versa isn't lasting as expected, I'd like you to wait until you need to be charged again, when you receive the "low battery" message, please fully charge it, restart it and try the battery last longer tips in this post. Keep an eye on the battery level and let me know how fast it is draining or if the issue got solved.
Let me know the outcome!
Best Answer10-06-2018 15:42
10-06-2018 15:42
Best Answer10-06-2018 19:59
10-06-2018 19:59
Best Answer10-06-2018 21:16
10-06-2018 21:16
Best Answer10-06-2018 23:07
10-06-2018 23:07
I'm having the same with mine I've had to practically disable everything. Part of the reason why I got mine was so I can keep an eye on calls and messages whilst at work
Best Answer10-07-2018 05:43
10-07-2018 05:43
Is it within the warranty period? I ran the test they suggested and it still was not
holding the charge so they are replacing it.
Best Answer10-07-2018 06:08
10-07-2018 06:08
I’m having the same problem. I bought my versa in may and everything was working excellent but about a month ago my battery last about 5-6 hours as limit when it was lasting about 1-2 days. I haven’t touch anything in the watch so I don’t why my battery dies so fast now.
Best Answer10-07-2018 06:44
10-07-2018 06:44
Best Answer10-07-2018 09:51
10-07-2018 09:51
Best Answer10-11-2018 05:33
10-11-2018 05:33
Hi guys, I hope you are doing fine.
I am sorry to hear about the issues you are having with your watches battery life. If you have already tried the instructions provide in this post and keep experiencing this, I recommend getting in touch directly with our support team, I know they will be glad to help you out. For a faster response you can contact them via chat.
Catch you later. ![]()
10-11-2018 17:04
10-11-2018 17:04
So I haven't forgotten about this, I ran the recommended test and I actually saw a drastic increase in battery life, it jumped up to using about 14% battery per 24 hours. I'm continuing to test enabling some of the features one at a time to see which one(s) are the culprit. So far it looks like the 'Quick View' option (i.e. just twist your wrist to turn on the screen) is the big bad. After enabling that feature, my battery has dropped 79% in 24 hour and 12 minutes.
I have turned it back off and am fully charging my fitbit back up, and I'm going to run the same test with only all-day sync enabled to see how that affects it. I'll be sure to write back in a day or two with more results.
Best Answer10-11-2018 17:59
10-11-2018 17:59
Best Answer10-11-2018 18:54
10-11-2018 18:54
I have been charging my Versa for four days. It will not charge above 3%. I have tried varous USB port sources. I have cleaned the unit with rubbing alchohol. This is my second Versa. The first would charge. I spend more time charging and trying to trouble shoot than acutally using the Versa. I would really just like a refund at this point. I spent my workout time trying to fix my Versa. Very disappointed.
10-11-2018 21:21
10-11-2018 21:21
