07-15-2018
13:39
05:47
AlejandraFitbit
07-15-2018
13:39
05:47
AlejandraFitbit
Since the last update the bottom button does nothing on the Versa. I used to be able to use this button as a short cut to view the weather. Now when I hold it down it does nothing. How do I set it up again to use as a shortcut?
Best AnswerOn the first page of your Apps screen (reached by a left swipe), what App Icon is in the left lower corner? That is what is invoked when the right lower button is pressed. If there is no App Icon there, that is why you get nothing when pressing the lower button. Move Weather into that place.
@Glow-worm wrote:Hi! Thanks for the reply. I don't have this app. Do you know where it comes from? Cheers
I believe you do. You need to spend some time with the User Manual and see particularly pages 21 and 26-27 which cover your current concern.
07-18-2018
05:49
11:38
07-18-2018
05:49
11:38
It's great to see you here @Glow-worm and @SunsetRunner thanks for stopping by.
I would like to know if you keep having issues with your watch's button? If you do, you may be able to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air. Hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button. After this, restart your unit.
Let me know the outcome. ![]()
Alejandra
I’ve only had my versa for a few months, and my bottom button has never worked since the first day I got it. I have tried restarting, moving apps around, pressing all three buttons at once, and have read through the forums trying to find a solution. The button feels no different from the others in terms of feeling blocked- do you still advise trying to remove dust as a potential solution for me ? Are there any other things I could try ?
thanks
