10-06-2018
15:34
06:43
AlejandraFitbit
10-06-2018
15:34
06:43
AlejandraFitbit
Hi there,
Yesterday I received a new Fitbit Versa. My initial one had a slightly damaged bezel out of the box. I noticed that under the same circumstances, auto brightness creates different results on both screens. The new Versa is slightly less bright, while the damaged one really pops out. I tested them by wearing them next to each other. The question is what to do: swap the new one for another new one? Is it faulty? Or is it just the way screens can differ from each other?
Thanks for your replies in advance!
It's great to see you around @suijkerwerk.
Thanks for troubleshooting this by yourself. If you haven't tried the restart process, I recommend restarting your watch by doing the following:
Also, I suggest checking the brightness level by swiping to settings.
Let me know the outcome. ![]()
Best AnswerHi Alejandra,
Thanks for your reply. But as said I already tried all options. It didn't Help.
Now, it is acceptable, but the brightness is just less vivid.
Thanks for the update @suijkerwerk.
Since the restart process didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted. ![]()
