10-13-2018 21:29
10-13-2018 21:29
So I’ve had fitbits for years. I bought a Fitbit Versa like two months ago. I’ve been getting bumps on my wrist. I have three bumps (almost like acne) right now. I wear it loose, I take it off when I shower and I’ve never had this issue with any other Fitbit.
Tried to attach a picture but cannot figure out how...
Help?!
Best Answer10-13-2018 22:50
10-14-2018 08:21
10-14-2018 08:21
They are under the sensor
Best Answer10-15-2018 20:50
10-15-2018 20:50
@Christylyn Several users on this forum reported the same problem. If I recall correctly they didn't have issues with other fitbit sensors just versa. My recommendation: remove Fitbit and let the hand heal. You can try and wear it on the other hand. But, if you develop similar bumps, I'm afraid it's an allergic reaction. 😑
