Hi there, I've noticed some individuals stating compatibility issues with the Versa and the Huawei P30. It is now listed currently under the phones that it is compatible. Does this mean that the issues is sorted out? I want to upgrade and want to make sure before I do that my device will work 100%. Thank you
Hi @Charlene1234 , yest it is!. See this. Click the link, scroll down a bit and press "Android Devices". Scroll down to Huawei and you wil see that the P30 and P30 Pro are listed. Regards kuzibri
