01-16-2019 06:20
01-16-2019 06:20
Hi all,
I charged my Versa overnight and when I put it on this morning, my digital clock format had changed to show seconds, instead of just hour & minutes. I can’t figure out how to change it back. Any suggestions? Thanks.
01-16-2019 10:32
01-16-2019 10:32
I just communicated with the developer. This clockface had just been updated to add the seconds as many medical professionals had requested it. He is working on adding the option for users to be able to choose whether they want seconds or not.
01-16-2019 07:02
01-16-2019 07:02
Mine did the same thing this morning! I can't figure it out.
01-16-2019 07:19
01-16-2019 07:19
Which Clock Face are you using, one of Fitbit itself or a Third Party one? Would you be so kind to send me the name of the Clock Face: press Clock Faces and you get the screen with "My clock" (which also tells you the name og your clock) and "All Clocks" ?
Best Answer01-16-2019 07:20
01-16-2019 07:20
I came here to figure out the same thing... I don't need or want seconds showing but I can't find an option to turn it off.
01-16-2019 07:55
01-16-2019 07:55
Same thing on my face this morning. I am using "March Blossom" face
01-16-2019 08:05
01-16-2019 08:05
Hi, the March Blossom is a third party Clock Face. Sometimes these faces are not fully compatible with the new Firmware version, leading to this kind of problems. When you go to My Clock is there on the right side of the name a settings icon? If yes, press it and see if there is a possibility to swith the secs to off. If not, you have two options:
1. Restart your Versa and see if the problem has solved, sometimes you need to do that more than once.
2. Install another Clock face, preferable one of Fitbit it self. The Layers face is Versa's default one.
01-16-2019 08:28
01-16-2019 08:28
I am also using March Blossom. I tried a different clock face and it was not showing seconds. Would you suggest that I contact the developer of the March Blossom clock face?
01-16-2019 08:58
01-16-2019 08:58
That's a possibility, but I'm afraid that it will take a long time before the Clock Face will be updated by the developer.
Best Answer01-16-2019 09:17
01-16-2019 09:17
Thank you. I reached out to the developer and the addition of seconds was intended. I’ve switched to the layers clock face.
01-16-2019 10:32
01-16-2019 10:32
01-16-2019 10:47
01-16-2019 10:47
The developer says the seconds were requested by users. He plans to make it optional. I tried another watch face, and didn't like it. I guess I'll wait for the next update.
01-17-2019 08:34
01-17-2019 08:34
Did anyone elses battery start draining? Trying to determine if it's the added seconds feature to the clock face or if I am having an issue with the watch itself.
Best Answer01-17-2019 08:46
01-17-2019 08:46
01-17-2019 21:49
01-17-2019 21:49
If you figure it out let me know its my fsv face and it was all the sudden we have seconds... I don't like seconds on there...
Best Answer01-18-2019 06:15
01-18-2019 06:15
Best Answer01-19-2019 04:16
01-19-2019 04:16
Mine too. Very annoying
Best Answer01-19-2019 08:51
01-19-2019 08:51
Thank you for posting this - the same thing happened to me, and I thought it was me.
Glad the solution seems imminent.
Best Answer01-23-2019 09:44
01-23-2019 09:44
The update is now available. If you go through the app to Clock Faces - my Versa - you will see the Update button. Once you update, the seconds will be gone.
01-23-2019
13:08
06:47
AlvaroFitbit
01-23-2019
13:08
06:47
AlvaroFitbit
Thank you!
Moderator edit: removed personal information
