09-25-2018
09:29
05:58
AlejandraFitbit
09-25-2018
09:29
05:58
AlejandraFitbit
Having had a Charge 2 I decided to purchase a Versa for swim tracking. I was sitting down and the Versa slipped from my wrist and fell face down. The screen badly cracked even though it fell less than 2 feet. Not only is it very noticeable but it is no longer waterproof. I was informed not only does Fitbit not fix this but they do not sell nor is a replacement available enabling me to take the Versa to be fixed privately. Can you imagine buying a watch or any product that can not be fixed? It was only after the glass broke that I saw all the comments about the glass fragility in community posts I believe that Fitbit should have recommended a screen protector in their advertising. I certainly would have purchase one. I have never had a watch or any other product with a glass screen that could not be repaired. Basically Fitbit is saying your Versa can’t be fixed throw it away and the 200$.
Best Answer@Marilynps If you purchased with a credit card, you should check with your bank. Often, credit cards offer extended purchase protection. Additionally, you should check consumer protection laws in your area. In another thread, a commenter mentioned that there are laws in her area preventing manufacturers from refusing to cover "wear and tear" damage for the first 6 months of ownership.
Depending on where you purchased and when, the retailer might also exchange it for you.
I learned the hard way about screen protectors when I scratched the screen of my Ionic while making my bed. Good thing I was within the 30 day return window from Amazon and they replaced it for me!
09-26-2018
05:56
05:45
09-26-2018
05:56
05:45
Hey @Marilynps, it's great to see you around and @meresydotes thanks for stopping by.
I am sorry to hear about the damage on your Versa. Upon checking with our support team, I was told that you have already created a case with them. I think this is great and know they will be glad to help you out and provide you with a solution.
Let me know if you need anything else. ![]()
Best AnswerFitbit does not repair any of it's devices. They consider them all disposable. The labor to repair would exceed what the device is worth.
Thanks for your suggestion, My Credit Card Company may reimburse me. However, I am angry with Fit bit for not mentioning in advertisements that it is advisable to purchase a screen protector. All of this could have been avoided has i known in advance that one was needed. The supposedly super-hard glass scratches and breaks much more easily than glass usually used in watches.
I get it. Unlike Apple they don't fix their devices. However, I wanted to purchase a glass and take it privately to be fixed by a technician. Not only does fitbit not sell replacement glass or suggest where it might be obtained, they informed me that the cracked screen on a Versa can not be fixed!!! Had i know this ahead of time I would have ppurchsed a screen protector, or more likely< decided not to Purchase the Versa. I see it as a DESIGN FLAW!! The frame does not protect the glass as it does on my Charge 2!
https://www.aliexpress.com/item/4000439643674.html?spm=a2g0o.productlist.0.0.414c7368WOaMef&algo_pvi... maybe this would help?
