12-18-2018 20:33
12-18-2018 20:33
The display on my Versa started glitching recently whenever I try to use it aside from just looking at the homescreen, for example if I wanna go to the alarms or stats or anything I start getting these white lines across the screen and sometimes the entire display goes all white with red lines and I can't use it. So far it has returned to normal after leaving it alone for a while but as soon as I try to use it again it starts acting up. I wonder if anyone has had that issue with their device and what can be done to fix it.
Best Answer12-18-2018 20:37
12-18-2018 20:37
@NoorWatey have you tried rebooting your versa several times by pressing and holding the left and bottom right buttons until fitbit logo flashes?
12-19-2018 05:47
12-19-2018 05:47
12-20-2018 01:00
12-20-2018 01:00
@NoorWatey I would probably side with you on this one, but before you reach out to Customer Support, I would recommend giving a factory reset a try. This will wipe your data from Versa so sync it first. Before factory reset, make sure you have deleted versa from your Fitbit mobile app and from your phone's Bluetooth settings. To perform factory reset, open settings app on you Versa and scroll down to About. Tap it and choose factory reset. After factory reset you will need to set up your versa again by adding a new device in your Fitbit mobile app.
02-11-2019 20:27
02-11-2019 20:27
@NoorWatey did you manage to resolve the issue?
02-11-2019 20:29
02-11-2019 20:29
Yeah I contacted support about it and eventually they decided that I should receive a replacement
Best Answer02-11-2019 20:33
02-11-2019 20:33
@NoorWatey That's awesome news! I'm glad. 😊
02-11-2019 21:08
02-11-2019 21:10
06-07-2020 10:07
06-07-2020 10:07
Can they still give you a new one if you’re is out of warranty?
