03-15-2019 12:14
03-15-2019 12:14
Hi. I really like the Versa, but would really like it better if the day were shown on the display with the date. It must be available because the alarms rely on it. There is room on the display and it looks like just a software upgrade could make it happen.
The Versa is the first tracker to actually replace my digital watch because of the alarms and timers. Just need this one last feature. Sounds corny, but a lot of retired people have trackers and having the day of the week available is helpful.
Thank you for your time.
03-15-2019 12:24
03-15-2019 12:24
Hi, if you're still on the original Clock Face that came with the Versa, you can change the Clock Face by following these steps:
1. in the dashboard of your Fitbit app press the watch icon on top of the screen on the right side
2. you will see the page with theClock Faces and App tiles
3. press the clock Faces and after that "All Clocks"
4. on top of the list you're getting you see "By Fitbit" and press right next to it "Show All"
5. Press that and scroll through all the faces Fitbit has to offer.
If I might to a suggestion: Scroll down untill you see "Business" clock face, which has day, date, steps and battery on the home display. Press it and choose "Select" and it will be installed on your Versa. Good luck!!
03-19-2019 09:15
03-19-2019 09:15
@RonaldH Welcome to our Fitbit Community! I'm sorry for the late response. However, I want to follow up and would like to know if you were able to change the clock face on your Versa after following the great steps that shared @SunsetRunner.
If you found his post helpful, please mark it as an "Accepted Solution" so other users can check it out.
In addition, I'd like to share the Versa manual so you can learn all its features and get the most out of it.
Let us know if you have more questions! ![]()
06-07-2020 09:30
06-07-2020 09:30
Yours is the one and only source I've seen that suggests that the Versa does have a day AND DATE clock face available. Could you please confirm?
