04-18-2018 10:42
04-18-2018 10:42
Just set up my Versa and the screen is too bright, the background is grey not black?
any ideas or is it to be sent back?
04-18-2018 11:31
04-18-2018 11:31
The background is a function of the clock face. There are many clock faces to choose from. Some, I'm sure, that allow you to change the background and/or background color.
04-18-2018 11:16
04-18-2018 11:16
You can adjust brightness (between dim, normal, max, or auto) in the settings app on the device. I generally keep mine on auto so that it's responsive to the light around me, but you can put it on a manual setting if you're finding it too bright generally.
04-18-2018 11:26
04-18-2018 11:26
Ive moved it from auto to manual but it’s still grey, nothing like the image in the adverts that show a black background?
04-18-2018 11:31
04-18-2018 11:31
04-18-2018 11:40
04-18-2018 11:40
Yep cheers, read the manual and changed the clock face.
looks like it’s going back.
05-20-2018 14:24
05-20-2018 14:24
Manual? Where is it? I haven't been able to find one.
Thanks... Bob
05-20-2018 14:41
05-20-2018 14:41
@Agunat wrote:Manual? Where is it? I haven't been able to find one.
Thanks... Bob
Versa User Manual.
05-20-2018 16:01
05-20-2018 16:01
I found and downloaded it. All is good.
Bob
