Try a Restart and do it several times if necessary. But first, make sure your Brightness setting is not set to Dim. That setting is reached by swiping left to Settings and Brightness is the top one.
Ok, so this is happening to me and I cannot change the "Brightness" setting off "Dim" - it's there, but ghosted/unselectable.
Best AnswerBrightness was greyed out for me when I activated sleep mode. Make sure sleep mode is off. Hope this helps.
My "brightness, do not disturb and screen wake" displays are all dormant and I cannot find a way to activate them, can anyone help me please?
Best AnswerSo happy it worked for you!
Best AnswerSame with mine. Rebooting several times does not help. Display is dim and in "settings" the brightness,sleep mode, do not disturb, and screen wake settings are greyed out and unresponsive to touch.
Best AnswerIm having this same problem! It was fine one day and now all of a sudden its really dim. All my settings are correct and I have restarted it and still nothing.. Looking for some advice too!
sleep mode was on , cannot believe customer service had no idea what was wrong. thanks so much. is a bit confusing have to tap on and that turns to off🤔
