06-26-2018 10:54
06-26-2018 10:54
Recently the display on my Versa is very dim. Any way to fix this??
Best Answer06-26-2018 13:25
06-26-2018 13:25
Try a Restart and do it several times if necessary. But first, make sure your Brightness setting is not set to Dim. That setting is reached by swiping left to Settings and Brightness is the top one.
06-26-2018 13:25
06-26-2018 13:25
06-26-2018 17:46
06-26-2018 17:46
Ohhhh thank you!!! Not sure how it got changed! All good now!
08-22-2019 03:38
08-22-2019 03:38
thank you
Best Answer11-04-2019 10:21
11-04-2019 10:21
Ok, so this is happening to me and I cannot change the "Brightness" setting off "Dim" - it's there, but ghosted/unselectable.
Best Answer11-25-2019 04:21
11-25-2019 04:21
Mine is to has anyone answered this?
11-28-2019 07:00
11-28-2019 07:00
Brightness was greyed out for me when I activated sleep mode. Make sure sleep mode is off. Hope this helps.
01-07-2020 20:46
01-07-2020 20:46
My "brightness, do not disturb and screen wake" displays are all dormant and I cannot find a way to activate them, can anyone help me please?
Best Answer01-07-2020 20:50
01-07-2020 20:50
Thank you so much, everything is now working A1, you were so helpful 🤗🤗
02-13-2020 15:00
02-13-2020 15:00
So happy it worked for you!
Best Answer08-20-2020 08:51
08-20-2020 08:51
Same with mine. Rebooting several times does not help. Display is dim and in "settings" the brightness,sleep mode, do not disturb, and screen wake settings are greyed out and unresponsive to touch.
Best Answer08-27-2020 06:50
08-27-2020 06:50
Im having this same problem! It was fine one day and now all of a sudden its really dim. All my settings are correct and I have restarted it and still nothing.. Looking for some advice too!
08-28-2020 13:34
08-28-2020 13:34
10-10-2020 11:47
10-10-2020 11:47
sleep mode was on , cannot believe customer service had no idea what was wrong. thanks so much. is a bit confusing have to tap on and that turns to off🤔
10-11-2020 19:36
10-11-2020 19:36
Best Answer03-27-2023 05:11
03-27-2023 05:11
Thanks for advice worked straight away after turning sleep mode off.
