03-31-2020
05:33
07:11
EstuardoFitbit
03-31-2020
05:33
07:11
EstuardoFitbit
Hi,
I have a versa which I haven't used in a few months, and put it back on now. I found out it doesn't vibrate anymore at all. I tried a factory reset, and I tried whether or not the vibrationmotor still works with the timer. I just won't vibrate. When I hold the watch close to my ear I can hear some sound coming from it, but it won't vibrate in any way. Does anyone know what to do?
Hi @Mandytje86 - I suspect your vibrations were inadvertently switch off. To check, try this:
If that does not help, try this:
Best AnswerThanks! But this doesn't work. I think I should get it repaired...
Best AnswerI had a similar problem with mine. You might try holding down the one button on the left side. It will come up with screen wake and notifications. Make sure both are on.
