10-17-2018 18:04
10-17-2018 18:04
Is there a way to get the Versa to measure distance and track when kayaking?
10-17-2018 21:20
10-25-2018 08:00
10-25-2018 08:00
10-25-2018 08:05
10-25-2018 08:05
I tried using the "run' feature when kayaking yesterday. It didn't work very well since it paused every time I stopped paddling. Then it was searching. Each time I paused my paddle, my Fitbit vibrated. Kayaking isn't like running in that we are not continuously paddling. We take some strokes and then glide through the water. We pause to look at wildlife. It seems, since Fitbit is on the wrist, and paddling involves movement of the arm, they could figure out how to measure number of strokes (like steps) and distance. One exercise could cover many paddling sports - kayaking, canoeing, paddle boarding, rowing. I hope they add an appropriate exercise choice because while paddling for 2 1/2 hours, I don't like to receive a notification that I should "get up and move". 😉
07-22-2022 09:46
07-22-2022 09:46
I have had good luck using the elliptical when kayaking or swimming because you're just using your arms is better
Best Answer07-22-2022 09:47
07-22-2022 09:47
Choose swimming or elliptical are the best two I've used swimming because using my arms I figured was better than elliptical
